jelag said:Before you adjust the cable on rear drum brakes... . make sure that your rear shoes are correctly adjusted... . often we don't back up enough to self adjust the rear brakes..... and if you adjust the cable with the rear shoes out of adjustment you won't get good results... .
Get the wheel off the ground... . and use a screw driver or adjusting tool and adjust the "star adjuster" while your spin the tire... . if you have limited slip you'll have to have both rear wheels off the ground... . keep adjusting until the brake shoes start to drag in the drum... ... . start the truck and pump the brake pedal a few times to recenter the shoes... ... and check them again... . most of the time we find that you end up spinning the star adjuster 3 or 4 turns to take up the slack. . and now not only does the brakes function better but the emergency brakes usually come in where it should... .....
Do the same on the other side... and you've got it..... Hope this helps...
HEMI®Dart said:JSimoneaux,
Jim's post is right on the money. Put a floor jack under rear differential. Make sure parking brake is released. Get a light. Remove one of lower the rubber dust plugs (not the ones that are further up of the backing plate. These are to inspect shoe lining wear) shine the light in and see it the hole lines up with the star wheel. If it does not, remove the other dust plug.
Get a medium sized screwdriver. Spin the wheel. Listen to hear if there is brake shoe on drum noise. This is the drag noise. If the wheel "backs-up" after you stop spinning it, this is a good sign you shoes are out of adjustment.
If they are out of adjustment, while spinning the wheel, use the screwdriver to click the star wheel UP. Try 1 click. If you don't hear the shoe on drum drag noise, go another click till you hear a slight drag. If you drums are warped (if they have been turned once) you may only hear the drag in a certain spot. Don't go to tight on your shoe to drum drag. You only want a slight drag.
After this adjustment you will notice the parking brake will work with much less pedal travel, and your regular brakes will work better (less pedal pressure needed). You can feel the rear shoes working.
Let me know how you made out.
Let us know how you made out
Nate said:Plus you can't turn the star wheel backwards anyhow. At least not on my truck.
I turn it until it drags a bit. It's hard to tell on my truck though with the Detroit locker.
jtisdale said:I think there was also a TSB for the cables stretching, but there is some adjustment on them. My e-brake is out of wack also and I need to re-adjust the cables and the star wheels.
Ragain said:Yes. The previous posts were for parking brake adjustment on disk brakes.
Ragain said:JSimoneaux... . I don't see info on your truck. Do you have a model with rear drum brakes?
I think the thread started with parking brake adjustment for rear disk brakes.
