Emergency brake light abs On Please Help!!!
Solved - Urgently Need Engine Barring Tool - Medford, OR
24v Limp Mode; max 1400 rpm
Emergency brake light and abs light keeps coming on and off. Began loosing braking power. So i replaced a sensor re-did the brakes fluids where all good. Recent oil change, reflashed Ecm . lights went away for a month. They are back on. And noticed loosing braking power again just not as much as b4.
Also recently my truck acts as if its in neutral in the first 4 minutes of driving it at slow speeds i let of the gas and then it engages.
Someone hep im at loss for what to do. Daily driver this is my only rig. Pretty please
Hey Kassidygee, Welcome to the TDR! May I suggest creating a signature with info about your truck this way when you post for help folks can better help knowing year trans etc. Go to upper right corner and hover over your name you'll get a pop up window, click on signature and enter info. Don't forget to check the box towards the bottom of the signature page that says (WTE) include signature in all posts. I
m sure someone will jump in with some help when they know what year and such.
Hey Joe,
Doesn't say "TDR Member" in his avatar so I do not think he can do that without coughing up the enormous $35.:D
Didn't think visitors could post in 911. Also she has similar post in 2nd gen forum. Seems folks are asking same questions = what year etc.
I don't know all the stipulations and maybe just a glitch and she is a member but TDR does not have the logo in the avatar. Seem's someone else had that happen.
