I recently noticed that my 94 Turbodiesel doesn't immediately start up when cranking. After I replaced the starter contacts, it would start before turning over 1 or 2 revolutions. This is all in weather 50 to 110 F. Now it takes maybe half a second to start. Also I've noticed some soot on the bumper, where I've only noticed it on the fender immediately above the exhaust.
I replaced the fuel filter-and filled the new filter with diesel. I pushed on the button near the fuel pump with that 10 mm nut loosened (getting the air out at the top of the filter), and afterwards the truck started after only a couple of tries. I didn't crack any injector lines, is this necessary? Is the 'prefilter' something I should look at/clean etc.? I noticed the 'word prefilter' in the Dodge manual, but was only concerned with the filter at the time. Although I noticed there was fine dust leaking from the old filter after it had drained (apparently it really needed the filter) it was caught by the filter, correct?
I also replaced the paper air filter and thought the hesitation while starting went away, but it only starts the same as before now. Sometimes it WILL start immediately without any cranking, but it's rare when before it always happened.
Another thing that has recently happened that I am sure was not there before. After I turn the truck off, I can smell diesel. I'm noticing it when I open my door, after turning the truck off. I look for diesel on the ground but don't see any.
After all of this, I have been trying to tell a difference in the power while driving. I think it has gone down a little, although anything past a point doesn't do anything. IOW, I don't go any faster or accelerate any quicker when I depress the pedal past a fairly high point. There is a lot of pedal left. I always drive with traffic (except while accelerating, it's fairly slow then) and easily cruise at 70+. I've never driven 80 mph, but it's been at 75+ and I'm pretty sure it would go to 85 maybe, I have never tried.
Any advice/information is appreciated. I'd like to 'stay on top' of any potential problems developing. It has about 210,000 to 215,000 miles, and I've had it since about 192,000 miles.
