Ok, haven't posted here in forever but here it goes.
I have a 2005 4x4 2500 QC LB with the G56 transmission, owned since new, pretty much stock, just a drop in non-oiled aftermarket AFE air filter, X-Monitor gauge to watch EGTs and boost pressure with cool down timer. I developed excessive pressure/smoke coming out of my oil cap when it was removed and blow by tube spewing oil and smoke but no check engine light. I shut the truck down, killed the cool down timer. Had it towed to a shop that I had just had replace the injectors 6 weeks prior as I had 237k miles on original injectors and it was probably time. They checked their work and said it wasn't injectors, I didn't think it was either. Options were to spend $1k to do a compression check or $11k to do an engine swap. I chose option 3, tow it home and pull head to see what's going on and confirm my suspcions.
Just finished pulling the head today and it looks like it is cylinder #3, scored sidewall, so I'm thinking broken ring(s). Just wondering if there is any shops in the Sacramento area that anyone would recommend to rebuild it or should I just buy a rebuilt one from someone like DFC in Edmonton? Looking for any thoughts or opinions that anyone has, I just wasn't expecting to have to do this level of engine work this early in this trucks life.
Thanks for any input,
Dan
Dan
