engine 5.9l
Idles fine but take off and it dies
06 5.9 cummins install NOT GOING IN
a 2004 ho short block with a 2006 ho cylinder head going into a 2006 mega cab..will it work
Yes, but if it's a early 04 the injector nozzles will need to be changed out for 03-04 ones.
It's actually quite common for 04.5-07 rebuilds to get 03-04 pistons.
I generally recommend a custom tune to go with it, but it should also work fine with stock injectors and a stock tune.
