Engine and transmission mounts.
SMELL'S LIKE BURNING OIL
Help Dana 70 Leak!
I swear, I have the only motor mount for our year trucks on the east coast, and my supplyer says they don't even list the transmission mounts (manual). I don't have a "five-star" dealer around here, so does anyone know where I can get aftermarket mounts even polyurathane would be cool. Something is better then one in a box. Thanks
1992 W-350 Club Cab Dually 3. 5" straight pipe(thanks jardine!)
W-350 8' contractors dump with 3. 5"BD exhaust, 16cm^2 housing, DI pyro&boost
Russell
If you find any please share. My transmission bushings look rough. They are all squished out and swollen. Good luck.
93 W350 5spd White 3. 54 gears 4" stack Powerwagon Injectors. Headache rack with lights. Cummins Mudflaps. 2" lift on seat. Goosneck ball Beefed up reciever. Fog lamps, Back up lights. CB 98 Factory sound system
Scott,
You know it isn't promising when you post something on the TDR and see a fat zero next to it for any length of time #ad
Anyway if I find anything I'll let you know. You would think that some one would make polyurathane mounts for everything, but my findings show that they make mounts for every other thing oh well. #ad
Last time I bought a set at the Dodge dealer. My truck is very hard on mounts. I am on my 3rd set of engine mounts. I've had times when the truck will try to change lanes when you get on the loud pedal and then it comes back when you let off. One time I knew they were gone when I was ready to grab the shifter and as I mashed the clutch and grasped for the stick, I missed!!!! I have been looking for an aftermarket set for years, hopefully something with a higher durometer rubber in it (stiffer) so they won't hammer out so bad. Usually the passenger side one is squashed and out of plane. the transmission mounts aren't as bad to go out. I'll do some checking for you. I have a great local Dodge dealer.
later
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Check us out at:
http://donstractorrepair. homestead.com
Within the last month I purchased both trans. mounts and engine mounts. Got them from my Mopar Dealer. They were not in stock, however they arrived overnight. As with Big Don my truck seems to eat them up. (Must be because the truck is BLUE)
1989, 4x4,250, 5spd. Banks Intercooler and Exhaust, Corsair fan clutch, Kelderman air ride (Front & Rear), No-spin rear diff. Gear Vendors and all possible mods. to void warrantee
Out of the three first gens at my house, the one that tows and plows, is the one that is hurting. The other two seem fine. Another funny fact; looked under my dump today hunting for cause of vibration, slip joint, but the driveshaft was in backwards !!?? #ad
Funny and not all at the same time. #ad
