When I need to rotate my ISB 5. 9 over by hand, I get out my 1/2" breaker bar and put the socket on there that fits the bolts (4) on the damper. The torque on the damper bolts is high enough that turning the wrench slowly will rotate the engine versus tightening the bolts more. If you go the other way slowly it wont loosen them either. Is there a problem with doing it this way or should I use the alternator nut... or better yet the actual barring tool which I dont have?
Also can I rotate the engine slowly in either direction? I try to only rotate in the normal running direction... but I have gone backwards just a little bit once or twice.
I need to adjust the valves soon and also install my new (used with 10,000 miles) VP44 pump. I realize you only want to go in the normal direction during a valve adjustment... I guess I'm just talking about general repairs that may require you to rotate in reverse direction. Thanks TDR members.
