Engine behaves like Dr. Jekyl and Mr. Hyde
brakes pulling
turbo& wastegate
I've been noticing two distinct running modes of my engine. One "strong and smooth". The other "gutless and rough".
When I start the engine, it may idle rough with more than the usual amount of vibration being transferred to the steering wheel and accelerator. As I drive, the engine may become "strong and smooth" with less noticeable vibration.
Before I shut off the engine, I think to myself "will the engine stop smoothly" or will I have to "wait for the shake!" that causes anything loose in the truck to rattle.
A couple nights ago, I left the house for a new lift pump at CumminsNW. The truck ran beautifully:D, until my return trip home whereupon I could feel the engine vibration increase as I had to push a little harder on the go pedal to keep my speed up.
If this were a mechanically operated gasoline engine, I would suspect an intake or exhaust leak.
This past week I installed a BHAF and new lift pump. Changed the fuel filter last weekend.
Engine still exhibits Jekyl and Hyde syndrome.
Anyone have any ideas? :confused:
Do you have a fuel pressure gauge? I had the brushes go out in mine and when the pressure fell I would get a stumble, lose of power and a shutter.
I have a handheld gauge 0-30psi but I don't have the fittings to hook it up yet.
I replaced the lift pump on 2/9/02. I don't think lack of fuel is the problem. I have noticed the engine change while driving or idling.
