Can someone tell me where the coolant drains are on my 06' 5. 9 block. I have been all over the place under the engine and can't seem to find any.
Thanks
Thanks
All the small block chevys (1955 through 1990's iron block) had one 1/4 pipe plug with a 9/16 hex head on each side of the block that you could drain all the coolant out of each bank. They were in the middle of the block between cylinders 3 & 5 on the left bank and cylinders 4 & 6 on the right bank a couple of inches above where the oil pan bolted up to the block.
I think the big blocks, 366 thru 454 did also but I can't remember for sure about those.
When draining the block by pulling the bottom hose, does all the fluid drain out?
Would you get more out if the rear was higher than the front?
Just curious.
Ray
