engine block paint
How does the cold start solinoid work?
1st gen winch idea
What paint does Dodge use on their Cummins blocks. It is that charcoal color. I don't think it has to be very high temp resistant. I just want to touch up the timing cover and some of the other parts while I have the engine exposed. Thanks,
There is an actual cummins PN for the paint. I don't remember what it is but I do remember finding it just weeks after I painted my block with generic! ;)
Thanks, I don't think I'll make the trip to the Cummins shop so the generic will do fine. I'm not that much into authenticity, I just want to clean it up a little.
Donovan, it is a charcoal coclor, called bluke. Most use a gloss black that you can get most anywhere.
There are engine paints. You can find then at most any auto parts store. I use DupliColor Ceramic Engine Enamel (500°) No. DE 1613. This is for the engine, NOT the exhaust system. For that you'd need exhaust paint.
Here are the official Cummins colors and p/n's for spray bombs. I used Aprex Red and Bracket Black on my 03 when I rebuilt it. I don't like Bluke as it has the sun faded black look. Shadrach
Part No. Color Description
3824515 Paint, Cummins Beige
3824514 Paint, Cummins Titanium Black
3824516 Paint, Cummins Charcoal Gray
3824517 Paint, Cummins Marine Gray
3885910 Paint, Cummins Red
3885911 Paint, Cummins Bluke
3885912 Paint, Cummins Marine White
3885913 Paint, Cummins Onan Green
3885914 Paint, LaFrance Red
3823874 Paint, Komatsu Yellow
3885902 Paint, Cummins Ford Gray
3824989 Paint, Euclid Green
3824992 Paint, Natural Yellow
3885903 Paint, Bracket Black
3885906 Paint, Old Gold
3163075 Paint, Apex Red (Signature)
3162470 Paint, Mellow Yellow
3162471 Paint, Euro Gray
3162723 Paint, Beige Primer
3162872 Paint, John Deere Green
3885907 Paint, B and C Marine Gray
3885909 Paint, White
3164860 Paint, ISX Red 2
4919268 Paint, DAF Grey
4918660 Paint, Cloud White
I've used "official Cummins" marine white in the past meaning it had a Cummins label on it.
Crappy paint IMO. Some of the wrst I have ever used.
I'd take a can of Krylon or Rustoleum any day over that paint.
Hopefully some of the other colors are better.
Its CUMMINS BLUKE 3885611. It is a very hard paint when applied as directed. I sprayd the front end of my truck, the spring towers a couple years ago, and it has lasted very good, no rust showing as with the KRYLONS etc did. I even sprayed the Ice cube maker with it. It worked very good for that to, but replaced it because I did not know if it would be TOXIC or not so the old one is just sitting.
