Engine break-in tow
Gross Weight??
how to lower rear about 2 inches.Whats easy?
I have been told many times to tow something to break in the engine. All I have is a 3000 lb slide-in camper (no trailer). From what I have read/heard, this is not much of a load for the Cummins. How can I use this weight to perform the break in? I now have 6000 miles on the truck and still getting poor fuel mileage.
Thanks for your help.
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
Head for the mountains and go go go... .
99 2500 QC SB 4x4 5sp 3. 54 LSD 285/75/16 Rancho 9000s A. R. E. Camper Shell etc. etc.
Fill everything to the limit and head for the hills. you might rent a car hauler and load it up then go for a cruise. Have fun.
2001 2500 tow, camper, SWB, ETH, Bright white.
Take the cabover out on the interstate and run it at 70+ mph for at least an hour. Same as pulling heavy due to wind resistance...
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
The camper should give you sufficent load to break in your engine. I would tend to run faster to allow extra wind load. You will see 5 to 8 miles per gallon differnce between 50 and 75 miles per hour. That translates into LOAD on the engine. I would try to not lug the engine. Happy camping!!
1995 2500 5 spd bombed. 2001 ETH 3500 stock. 1972 1066 International Harvester 414 ci diesel pulling tractor.
GONZO
