Engine code help
Torque on front diff cover bolts?
??? Regarding Seat Wiring
The check engine light is on. Engine codes were P1693 and P0237. Anyone able to tell me what the are ? I only have a power edge box on now. Thanks.
Thanks BV,
I called dodge and they couldnt tell me. I think it has something to do with my pe box. Thanks again. Paul
Bbayer
I had the same code on my last truck "0237". The dealer ended up changing out my map sensor, because it wasn't putting out enough volts.
I had the same set of codes last fall. Before you install a new MAP sensor, try a dab of dielectric grease on each of the 3 posts withing the MAP plug, worked for me.
It's common for some of us to get the P1693 code with a fueling box. I just had that code re appear a few weeks ago, I checked the MAP plugs again ( I have 3 with the combo of the EZ and TST boxes ) and it appears that I missed one of the posts within a plug the first go 'round with the grease. I gave it a small dab of dielectric grease and magically, the check engine light disappeared and has not returned.
Scott W.
Thanks all. Gonna try the dielectric grease right now.
Bill I have your eggs their being sent air mail. haha
I tried the dielectric grease and it didnt work. Since its still under warranty I called the 5 star butcher and made an appiontment. Ill post the results when I get it back.
Re: Codes
Originally posted by BV
P0237 Turbocharger Boost Sensor A Circuit Low
P1693 Turbo Charge Control Circuit Malfunction
BV- Where did you find that 1693 was turbo related?
I don't have my tech man in front of me, I'm at work, but I think that 1693 is a communications mismatch between the ECM and the VP44 controller. I may have my PCU and ECU codes mixed up though. Just curious. :eek:
I started up the ram for my trip to the 5 star butcher and guess what?... Yup, the engine light was off. I guess the dielectric grease worked after all. Thanks a million Bigsaint! U R a life saver. I didnt have to deal with the butcher.
