My son has a pretty fancy code reader, we put it on and got several bad indicators. The biggest was a -40 reading on the coolant sensor. We scoured the manual and it claims there is a sensor behind the fuel filter, but it appears there is none there! Finally found the connector in the wiring harness for it, but it seems to be an open connector, and there is no "9 inch" jumper from that to the coolant temp sensor. We shorted it out and the code reader says it is hot.
I think I found the gauge sensor on the left rear corner of the head, but isn't there another for the PCM use? I have the factory manual and a Haynes, they don't seem to know either. What gives here?
