nascar
I have a re-occurring problem from last year. It cleared up, and now has returned. The engine will cut out and stumble while driving. This happens at any speed, with or without cruise control. Mostly it happens during interstate driving. It gets bad enough that sometimes I can't keep 55mph speed. This isn't the dead pedal syndrome that I've read about. This can happen at any pedal position. The way you can duplicate this problem yourself to see what I'm talking about is - Drive on the interstate at a constant speed, then all of a sudden, take your foot completely off the accelerator. Then, after about 3 or 4 seconds, put your foot back on the pedal for a few seconds, then repeat. It's very aggravating. It goes on and on. It's not only interstate speeds. It's has done it at neighborhood speeds as well.
Here's where it's weird -- If I start out with a cold engine (parked overnight), I've driven 75 miles without any problem. Problem only happens when the truck has been running already for the day. Not thinking it's the cam position sensor because tach works fine. I really don't believe it is anything mechanically wrong with the VP44. If it was, it should do it any time. It has something to do with heat I think. Although, that doesn't explain why I can drive it for over an hour without it acting up (as long as I start out cold in the morning). It only does it with a load on the engine too. I can press clutch and engine will hold a constant RPM.
I've searched forums for answers. Best answer I've found is it may have something to do with the VP44's electronics.
I will gladly replace the VP44, but I want to be 100% sure. Last thing I want to do is replace a injection pump and the problem still exists. I have replaced the MAP sensor already. That was $100 wasted!
Help!!
Help!!
