Hi Gearheads,
I drive a 1998. 5 24 valve 4x4 5 speed manual shift LWB. It has gages, Horton fan, Pac brake, a carter push pump as well as the stock pump. It also has a fuel pressure light that comes on at less than 5psi. It has no HP upgrades. I have owned it since new and it has 96500 miles on it, half of them towing miles. Never has given me a problem until tonight.
I fueled up and took a drive in the country. 50 to 55 mph. 58 miles after fill up I came to a stop sign and as I was comming to a stop I put in the clutch and it died. It will not start. Cranks fast but no start. I opened the water dump at the filter and only fuel came out. I turn on the key and I hear the fuel pumps working and the fuel pressure light goes out but it won't start, only crank. By the way the check engine light did not come on and is not on except for the first few seconds when it checks itself.
I have had the fuel pressure light only for the last 6 months, 4 or 5 thousand miles but it has never lit up while the engine was running. I don't think I have ever starved the V44 fuel pump. I put the extra pump and light on it "Just to be safe"
Any ideas on what it could be? Help.
Chris
Chris
