I have a 2002 2500 4x4 6spd. On Friday I was on my way home from a trip at 75 mph in the left lane and the engine started to die like it was running out of fuel. I got to the shoulder and it went dead before I could stop. When switching lanes I could see some gray smoke from the exhaust. I thought that I might have run out of fuel but the low fuel chime had just come 5 miles earlier and the gauge still read 1/8 tank. I have taken it all the way to 0 and still had 4 gal in it when I filled up. It was towed to the local dealer and I put 5 gal in the tank, the gauge wnt to 1/4 tank, before I cranked it. I can hear the fuel lift pump if I crank and then leave the key on the On position. I loosened the banjo bolt on the supply line to the injector pump and got no air bubbles just fuel. Torqued bolt back to 18 ft-lb spec. The check engine light does not come on. When I crank I get no hint that even one cyl. is firing off. No smoke at all from the tail pipe. I have a turbo saver from Geno's and thought that maybe it went bad and cut the run signal to the engine just like if the security switch is on. I took the turbo saver out and hooked up the ignition wiring back to stock. No difference. Any ideas? The dealer has not even looked at it yet because they only have two diesel guys one is on vacation and the other is working on a gasser. It kills me to pay for a rental car for 3 days before the dealer even looks at it. In addition I broke down 1. 5 hours from home.
