Archived Engine dies right after starting
Archived frantz filter owners read this!
Archived Very weird howling noise...HELP!!!
Getting worse now, especially when warmed up. THe engine will startup right away then immediately die. I have to hold the accelerator pedal down while cranking to get her to keep running. (She runs fine after that)
What year truck? If it's a 12 valve the idle is probably too low. An automatic should be at least 750 RPM with the trans in D with the AC on. 800 is better.
750 in D with A/C? OK I'll try that, Just an hour ago i adjusted it up to ~750 in neutral-drops down to 5-600 in D with A/c on. To get 750 in drive with A/C wont it have to be about 1000RPM in Park? Oh, yeah, the truck is a 97 12v.
Replace your fuel lines from the frame rail to the steel lines that go to the injection pump. I had the same problem. The fuel was draining back to the tank because air was getting into the lines. Do a search on fuel lines and you should find plenty of info.
Josh
