I found this in the current issue (Nov) of Trailer Life. Some of you may already be aware of these but for those of you that don't here they are.
NHTSA recall number 02V159 DC recall number B20
re: 46,000 2002 Dodge Ram pickups. (doesn't specify CTD or gas)
On certain 4 x4's, rear axle flange weld to axle tube could fatigue and allow the brake caliper assembly to rotate.
During the rotation, the brake line could seperate from the caliper, resulting in a brake fluid loss in the rear-brake hydraulic system.
Dealers will install rear-brake caliper reinforcement on the rear axle assembly.
NHTSA recall number 02V161 DC recall number B15
re: 97,500 1997-98 Dodge Ram CTD
The throttle linkage joints can corrode and cause the throttle to bind or stick, increasing risk of crash.
Dealers will replace the rod ends and ball studs.
Hope some of you find this useful.
DC Miller
Marbleman
DC Miller
Marbleman
