Hey guys I was driving today and I heard a chime and I look down and the light check gauges was on and I wasnt showing any oil pressure, so I turned the truck off asap and pulled over and I checked the oil and no oil loss and no oil leaking. So I drove it to a friends close by and I checked all the fuses and I pulled the connector off the oil pressure switch and it was fine and the I started the truck and I got oil pressue and on the way home it would drop to zero and then come back up it only dropped once what do you guys think? I running amsoil oil filter if that helps and I believe it has a bypass valve any input would be great!
