Engine Has A Miss? ? ?
'99 vs. 2001.5
The right numbers??
At around a 1000 to 1200 rpm the engine has a light miss. Usually under light throttle. When I step on it smoothens out. When it warms up its a little better. Its been like this since I have had the truck. I have 140,000 miles on it. It never has gotten any better or worse. I heard of what was called an engine stumble does this sound like I mentioned. As far as performance I been getting 21 to the mile. Power is very good.
Thanks Even A. Beck for the reply.
I moved the topic in the right spot now.
Thanks Jeff H
95 Dodge Ram reg cab,2500,5spd,Tweaked & Peaked Cummins Diesel, MODS, K/N filter,dual exhaust 5'' tips,Lost muffler,turbo silencer, ACCESORIES,ISSPRO turbo & pyro. gauges. Shell Rotella in pan. Fleatgaurd filters. 140k. on the OD.
If you can smell this message. I Farted
