OK so I am not the quickest troubleshooter in the world but I finally fixed my stumble problem and wanted to put the word out so others can maybe benefit. After checking and rechecking all the electrical connections on the truck, adjusting valves, changing filters, buying lift pumps, thinking I may have to buy a VP-44 and shaking chicken bones at the truck in a ritual type fashion I finally solved the problem with the help of these forums and Justin at Edge Products. In my case it initially wasn't the pump wire connection but the ground to the air horn (just like Jrandol said) Justin at Edge told me to put that wire directly to the battery and see if the problem went away and sure enough the stumble was gone but the truck still didn't seem as powerful as before and didn't smoke as nicely as before so I re-did the pump wire connection because I had taken it apart a few times during my troubleshooting process and was concerned about it making good contact since I re-used the old one (don't re-use scotch locks) and now all of a sudden I am worried about my clutch again. This truck once again rocks, Thank you Toolman, Jrandol, Edge and all the others that took the time to assist me in my troubleshooting and repair. I think to celebrate I might go to the 1 ton truck pulls in Greenwich on Sunday and see if I can destroy my clutch, then I have a good excuse to buy a new one. By the way if anyone is interested there are big rig truck pulls on Sunday the 24 th in Greenwich, New York, They had 60 something hooks last year including the really hot pullers and some local dump trucks and log trucks.
