I have a 2007 Dodge Ram 2500 5.9L Diesel Automatic with a Super Chip tuned computer in performance mode.
When I stop at a signal in gear the idle drops to 500 rpm, when I release the brake the engine revs up to about 1500 rpm then drops back to 750 without ever touching the accelerator. Then when I apply the accelerator it takes off really slow, like it was stock with no chip installed. The shift from 1st to 2nd seems like it is shifting harder than normal with little acceleration. When I am stopped with the brake on in gear and try to raise the rpm of the engine, no response.
Sometimes the rpm stays at 750 rpm at a stop and accelerates normal like it should.
I have replaced the MAP Sensor and air cleaner and still have the problem.
