About a month ago i turned up the fuel on the pump. I turned the fuel screw approx 1. 5 turns. This helped a little although not as much as i thought it would. It does have a little more power. Now i have noticed that once the truck has been sitting running(idling) for more than a minute after the engine is fully warmed up the engine idle somewhat lopes the rpms vary about back and forth about 50rpm(between 850-900)any ideas??? is this normal??? could there be anything wrong with the pump???
93 D250 5sp 3. 54 gears sans muffler, ISSPRO tach, K&N filter, needs to be bombed BAD
I would rather be cummin than stroken
