Engine Idler... Anyone using one??
Mechanical 8.3C Cummins.......
What is the max bore on a 5.9l ??
It seems like a lot of frills when a simple switch would do the job. You still have to provide the actual mechanisms to increase the idle.
The switch implies the driver has all of his smarts working all of the time.
The Kausmaul idler exits control if the neutral switch or the brakes get involved.
It's awful hot here in Phoenix, I think the convienience factor has to over ride the cost involved.
I have a high-idler from Home Depot.
Works in all weather, easy to turn on or off, performs double duty as a "tire-thumper", and cost about a $1. :D
