Engine/Transmission (1994 - 1998) Engine installation question
I'm putting a Cummins ,its from a 92 ,I know not much on the power but I'm going to run what I have for now .
The truck is a 98 v 10 truck I took it out in peaces .
Do I need to lift the cab or will it go in with out lifting the cab ?
Any help with expertise I'd appreciate thanks !!!!
So what did you do just set it at a angle then ,how did you hook to the back of the engine with the install ring or right to the block?
OK , Thanks I was thinking about making a flat bar to mount in place of the ring ,was there any issues by retorqing the head ??
