Can anyone give me some advice with a problem I'm having with a slight reving noise coming from the engine. While under power, I'm hearing this pulsating reving sound that is intermittent (2 - 3 seconds apart) and lasts about a second. It usually occurs when the engine is cold, and while accelerating, but has done it while cruising at a constant speed after the engine has warmed up. The RPM's do not fluctuate when this is happening, nor does the speed. It almost sounds like pump runs dry, and rev's up, then catches the fuel. I just had a new lift pump installed at 68K, thinking this might solve the problem, but it didn't. The original pump was weak but had not failed, so the dealer replaced it. Any comments would be appreciated.
_________________
2002 QC 4X4 Auto, 68K, BD chip, all else is stock
_________________
