Whoever says Dodge trucks don't have a mind of there own, think again.
Oh, I believe you. I have considered an exorcism several times because THERE IS NO RESON FOR THE WIERDNESS. :-laf
Mine has done the wiper thing since it was a month old. No reason or trigger, just runs the wiper cycle a couple times randomly.
The last 2 issues were even more disturbing. Started it up one morning, warm, dry, new batteries, all grounds and battery cables were cleaned, scraped, treated etc, and 15 seocnds after start the rail pressure went to max, rattled like crazy, and threw every code you can think of. Spent all day chasing ghosts, pulled every harness connection and sprayed it out with cleaner and made sure it was seated good. Nothing worked. One time I got a whole 5 minutes of correct operation but the next time I restarted back to the same problem.
Out desperation I drained the filter housing, filled it with SeaFoam and ran for a mintue to circulate it in the system. Started the truck the next morning and problem gone. In over 2k miles and not a single hiccup until the other day. For no apparent reason the transmission dropped out of OD and CEL lit up, stock tune loaded at the time. Stopped at a light and took off, no more issues. Checked the codes and it was P0148 and the WG controller code. My WG controller has had a fooler on it for 2 years that has never caused and issue. Cleared the codes and have put 1500 miles on it with a UDC tune on it. Averaging 18 mpg at 72-75 mph and it has run perfectly.
I dunno, if I didn't know that Dodge has one of the best EM programs in existence I would think the sun spot activity and frequent coronal mass ejections that are hitting us is the problem.
It is either that or it is possessed. :-laf
