Engine/Transmission (1998.5 - 2002) Engine light
Engine/Transmission (1998.5 - 2002) SMARTY and Tire Size Question
Engine/Transmission (1994 - 1998) exhaust
1693 doesnt mean much . there could be a companion code set in another place . since you have a 2002 you can get the code by turning the ignition key on off,onoff,onoff and leave it on codes show up in tje odometer window. let us know what it says.
I had the 1693 code using the key method and that was the only code that was there, used a code reader and got p0121, so there should be another code along with the 1693. :(
