Need help with an engine miss. My 95 has 250,000 miles, 160 h.p. with TST #6 plate, and 50 h.p. DDP Injectors.
I started to notice a miss after injector installation about 2 years ago. The engine will only miss around 900-1050 rpm after sitting for a while when fully warmed up. I've tried pouring water on injector pump but that did not help. I have the turbo boost line
disconnected and plugged. I have a boost gauge 35 psi auto meter and monitor it. Sometimes coming off idle, the boost will
increase according to throttle. Other times it's very slow coming up . The motor has never been retimed. Appreciate any help
with this.
Also, I have a question about fuel filters. I've always used FS1253 fuel filters. My vehicle is well-maintained. I switched to WIX
fuel filter about a year ago. Fuel filters WIX and Fleetguard come with and outer seal, a small round O ring, and a square cut
O ring.
These were always changed, but I noticed on the Fleetguard that if you take the small cut O ring and lay it on the filter above the
threaded mounting hole, it is not on plane with the outer sealing ring (approx. 1/8 to 3/16 below it). The WIX filter IS on plane.
What is the purpose of this small square cut O ring. I thought it was to force the fuel through filtration. Again, any help will be
appreciated. Thanks, Gary
with this.
O ring.
