Looking for ideas on what might be the problem on a 98. 5 24v.
It sounds like it is missing at idle and just about any other rpms. Also it seem rather guttless. I am not sure if it is related or not but keeps throughing a p0234 overboost code. I can run a scan and clear the codes then idle the engine for a couple of minutes and the rescan and the p0234 code is back. Will the p0234 code cause the truck to run lousy or is it even related? I have replaced the lift pump and fuel filter and the MAP sensor. Also replace the injectors. Nothing seemed to make any difference at all. I think maybe the VP44 is going out, but just want to make sure before I go spend $1500.
