Gentlemen,
A conundrum if you will. I have a 01 CTD 6spd, 50hp injectors with an engine miss. Our yearly road trip to AZ,
started to miss badly and deteriorated as we progressed. Found a good shop and decided the hi pressure pump was the culprit, original had 285k mi on it. Had injectors tested and were good. Fuel pressure 16-17lbs when it was missing, no codes at that time, no smoke. R&R'd the pump and life was good for 3,200miles. Now the miss is back! Codes P0234 & P1693, over boost and ECM/PCM detected a DTC, Power is also down. The pump is reman and the builder will test but if nothing is amiss, will charge for another pump not under warranty. Truck runs good unladen, again, no smoke when missing. Is the turbo at fault, perhaps a sensor on the turbo? ECM/PCM bad or on the way out? Thoughts, ideas are good!
D gerth
D gerth
