Have any of you ever had any trouble with the bolt pulling out on the motor mount on the torque side. I had a good pull going this weekend and the bolt came out of the slot for the motor mount causing my automatic transmission to pop into neutral. I did not know if my mount is just wore enough that I need to weld a small stop on top to prevent this from happening or if by chance this was an ongoing problem that could be fixed a better way.
Thanks in advance for the help.
