Engine Noise?? Is this Normal??
Auto Trans OR TPS?
Tow Hooks
I’ve got an engine noise on a new ’01 24v auto truck that really doesn’t sound normal. It’s sort of a high pitched chirping that seems to come from the left side of the engine. I’ve had a couple other 24v trucks and do not recall this noise. It’s like the engine is making 2 different sounds. You have the hum of the engine that we all live for, and then you have this high pitch noise that just irritates you to death. I only hear this sound when accelerating and cruising at or above 1900 rpms. It seems to get a little less severe after the engine is completely warmed up after a 30-40 mile ride, but is still noticeable. My only good guess is maybe the fuel pump or water pump, but have no experience to back that up.
I don’t feel like I’ve done a real good job of describing my problem but maybe somebody out there will know what’s going on. Thanks.
A frined of mine with an '01 had a chirping while accelerating but it was on the passenger side. It sounded like a bird was stuck in the turbo! Three of the exhaust manifold bolts were sheared off from getting it a little too hot (heat expansion I guess). The chirp was caused at higher boost pressure by the exhaust leak.
If it is on the drivers side, check the gasket(s) where the intake heater is...
Good Luck
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
78,000 miles (11/17/00)
