engine noise when turning engine off
Lift Pump - The saga continues!
Engine Cooling - high temps
Every time i stop my engine theres a high pitched squelling noise like the fan belt is sliping. The dealer says this is normal with this type of fan on the trucks. I have two friends that have 2000 and 2001 trucks and thay never had this noise. Any ideas on what it is or how to fix it would be helpful. :confused:
It's normal and won't hurt anything. That being said, if it annoys you to the point that you want to fix it yourself I believe that there have been good results posted about using the Goodyear Gator-Back brand belt.
good luck,
Mike
chjh9999
Your Cummins motor has a very high compression rating. As a result when the engine is shut off the motor stops moving in a very short amount of time. However all the accessories are still moving ( i. e. Alt, A/C, P/S etc. ). This results in a small belt chirp. When my first belt was getting old the chirp discontinued, but with a new belt it came right back.
