I friend of mine has a 94 model w/5 speed that doesn't seem to be pulling like it should. The engine has a TST torque plate on it, not sure which one, but it uprated the engine to 280hp/675 ft. lbs. When he hits a hill the truck loses speed. He said he gets plenty of black smoke, and he's cut out the cylinder and said all 6 holes are lit. The air filter is clean, the fuel filter is new, the fuel is known to be good.....
He tried pulling a trailer with the torque plate and it pulled horrible. He never pulled a trailer before the torque plate so I don't know if the problems started before or after the install. He has no boost gauge... but we may have to temporarily install one.
I feel like its not getting enough boost, although I don't know what the spec. is for that engine. All I have to go by is that my CR hits 34psi. but I think the mechanicals only hit about 18-20 psi??????
Is there an adjustment for the wastegate? if so, can somebody post a link to the instructions for doing so?
Also, it seems that I've read on here something about installing the plate "foreward" or "stock position"??? If there are different configurations for the t. q. plate, somebody please explain.
Well, and while I'm at it, what about the AFRC... he said he adjusted it "up and down " so I'm sure its jacked up... . I'm gonna try and help him fix it next weekend, but I'm looking for some good info to go by before I break out the wrenches... i hate to blindly just start twisting on things...
Any help would be GREATLY appreciated. Thanks!
