Engine number location
Block Heater Cord
Think I may have stripped pan bolts on transmission...
hi,
does anyone know the location of the engine number stamped into the 325hp cummins engine . i know there is the plate on the tappet cover , but i am looking for the stamped in engine number .
your help would be appreciated
regards conn
I don't know about the stamped number into the block, but the engine number is on the same sticker on the valve cover where the HP/Torque numbers are.
Stamped number can be found on the bottom of the oil filter/cooler housing boss.
Also your number can be found on the valve cover sticker.
