I have the truck at a dealer and it is showing boost and oil pressure with the engine off and key on through the ecm. I had codes for low voltage at apps, map and oil pres sensor set while I was working on it. It has little to no throttle response with the pedal, but runs fine using cruise control. He is not sure what is causing this. ANy thoughts?
