I have 2001 2500 Quad cab 4x4 with long bed.
How often do you change your engine oil? I've been changing mine every 4k. I tow a 4000 lb boat along with a 4000 lb slide-in camper 5-10% of the time, otherwise I am unloaded and drive 20 miles each way to work on the freeway. Could I go longer between changes with no worries? 7500 miles seems too long. Maybe 5k is ok?? I've been using Delo 400 and Fleetgard Stratopore filters.
What trans fluid do you use in your stock auto? Is the Mopar ATF+3 ok or is there something better?
What about engine coolant? Is Prestone ok to use?
I'm near 30k and need to change the transmission fluid and engine coolant.
