Engine Oil Cooler? Anybody using one??
Can't get tires to balance - what's the best balancing method?
Paintless dent removal
Has anybody out there installed an Engin oil cooler out infront of the radiator and if so, who make it and is it worth the trouble. I working at setting up for heavy towing.
Mundgyver : 2001 - 2500 QuadCab 4x4 139"WB, DK. Garnet Red Pearl Coat, Agate Inerior, Leather w/heat power adj both sides, 5. 9L HO 245Hp, 6 spd HD Manual, 3. 54 Axle, 21 Mpg Avg in town 24 Mpg Hw, OverHead Trip Computer/AntiTheft System, Mopar Tow Group Package. Add-on = EZ-Box=Haulin Butt, AMSOIL, PIAA SuperWhite 9004 HL's, Acrilic Black bug deflectors, Under Hood Full Radiator Bug&Gravel Screen, Cummins Exhaust Brake, Agate Dash Cover, AutoMeter SportComp Exhaust Gas/Boost/Oil Temp, Passport 7500 Detector, Garmen GPS III+, B&W Turnover Ball Model 1394R, LineX Bed Liner over the rails, Westin Step bars LineX coated. E-Mail at res02cke@gte.net -Working on the rest of the goodies as I can afford it.
You already have an oil cooler. You really think you need two!
You will not be able to create enough heat with your current setup that would ever get you in trouble. Many of these trucks running lots more fuel then stock and pulling extreme loads with no changes to cooling and no problems
jjw
Thank you, thats what I needed to know. I was not sure if the one built in would be enough during a summer run down south with a 5th wheel. Thanks
I dont think you could fit one if you wanted one anyhow. That grill has NO room for anything. One way i actually lowered my oil temps by about 15-20 degrees was adding the Amsoil dual bybass. The extra surface area from the aluminum adaptor, bradied lines, the aluminum filter block and the 2 filters makes for a giant heat sink.
