We have a problem at work with an ag tractor-Ford 555 3 cylinder diesel. I pulled and disassembled the engine,had the head and block boiled, magnafluxed, pressure tested, crank polished, block bored 20 over, new pistons, rings, etc. . the machinist swears he checked everything. Reinstalled engine, ran for 2 hours with no load, up to operating temperature, lost 1 quart of fresh engine oil into the cooling system. Ok so then I removed the thermostat and reflushed the cooling system, same problem again, this engine has NO oil cooler, will hold 18 psi on cooling system, also passed combustion gas liquid test. Any ideas or suggestions?Thanks in advance. Rick.
