There isn't any need for the cam timing pin. It is difficult to use and is sometimes the cause of oil leaks. When I assembled my engine I RTVd it into place. Find engine TDC using the procedure in the FSM for installing a new pin. That procedure is commonly called the drop valve method. Page 9-189 in the '97 manual.
It doesn't matter. Either valve will work.
“- the tappett cover is not leaking anymore but I do have an other bad oil leak (my hand palm every morning on the driveway...). It seems to leak by the little cover at the front of the transmission when running and 5 minutes or so after shut off. Main seal ?I've re-checked the rear valve cover and no leak. I might have a leak at the front gear cover because it's oily under the front of the engine, on the trans hoses and the cross member (under the pan). I will take more time this week-end to crawl under to have a look at the main seal and cam plug...
