I know I will draw the rath of all of the proponents for full synthetic, oil to be used in your engine. But in my humble opinion it is a waste of money and there will be no benefit in using synthetic oil in a STOCK 6. 7L CTD engine. Use the best Dino engine oil on the market such as Valvoline Premium Blue oil. This is cheaper then using synthetic oil in my opinion.
My reasoning is the oil will need to be changed almost every 5,000 miles or less, some might be able to get to 7,500 miles, but not a lot. The 6. 7L engine and the way the EGR system dumps the soot back into the engine along with the DPF using the extra fuel to burn off soot in the filter, this will kill the oil.
You will get fuel dilution because of the added fuel injection required for the DPF to regenerate. Some of the unburnt fuel will end up in the engine oil. Thus causing the fuel dilution to the engine oil and the synthetic oil will not help you here. Synthetic oil will break down just as fast due to fuel dilution as dino oil will.
Before I deleted, I use to have to change my engine oil almost every 3,500 miles due to fuel dilution to the engine oil. Now I can extend it out further and I have.
Jim W.
