Engine overhaul
Unfixable Oil leak
370 diamond B
I will be performing an overhaul on my 1995 5. 9 Cummins in the next few weeks.
I am looking for advice or suggestions as to what to do while I have my engine apart. I am looking for after market parts and the different modifications that may be performed to the engine and injection pump or anything else.
I am doing an overhaul due to poor air filtration. I would like some help in regards to enhancing the performance of my vehicle once the overhaul is completed. I also need any help in regards to part numbers on the marine pistons.
I am also looking for someone who has specifications or suggestions on porting and polishing the head.
[This message has been edited by LesEwen (edited 02-05-2001). ]
Les:
Welcome to the TDR Website!
Like you, I would like to hear from
some of the members on this subject
too. I know members like "Piers", "My 6
Eats V8's", "DieselB59", "HVAC", "Joe
Donnelly" and a few others can definitely
"cast some light" on this.
I am not there yet, but when I get
ready to do the "overhaul" here are
some things I am going to look into/
consider:
370 Diamond B Marine Engine:
Crankshaft, Connecting Rods, Ceramic
Coated Pistons
Better designed exhaust manifold,
possibly an "ATS".
You didn't say if you were looking
to "enhance performance" so I won't
go into alot of that.
Anyway, we will see what the other
members suggest.
Good luck on the rebuild!
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
Why are you going through the engine? I'm just curious. I had to rebuild a '93 cummins that was ran without an air filter for a few months. At the time I couldn't find many hi-performance parts, but I didn't look extremely hard either. If I had to go into my engine right now, I would port the head for EGT reduction and install a thicker head gasket to lower the compression. I believe this is only necessary for the extreme horsepower people. Hopefully, more people will chime in with tips for you.
-Chris
'94 2500 4x4 auto DTT TC/VB, Diamond B 370's, custom fuel plate, 4" exhaust, governor spring kit, AFC spring kit, hi-flow delivery valves.
