John,
What exactly did you do to bleed air from the fuel system? I ask because you need to make sure air is purged from not only the low pressure side of the system (lift pump to Bosch VP44 fuel injection pump) and the high pressure side (VP44 to injectors). The easiest way to purge air from the low pressure side is to loosen the fitting at the inlet of the VP44, pack a wad of rags under it, and bump the starter to activate the lift pump. When a steady stream of fuel comes out of the loosened fitting, snug it up. Next, to purge air from the high pressure side, you'll need to loosen 2 or 3 injector fittings at the head (loosening more fittings is better than less) and crank the starter for 5 to 10 seconds. If you have a helper, you can have that person crank while you observe the loosened fittings for strong squirts of fuel. Retighten these fittings.
Next, make sure your batteries are fully charged, hold the accelerator pedal to the floor, and crank the heck out of it! After some cranking you should at least get a cough from the engine if she's gonna start at all. If you get nothing, then the VP44 could be shot from being starved of fuel.
Please keep us posted.
John
