Engine RPM with the 3.73 VS 4.10
HO 6 Speed Noise in Neutral (louder than engine)
Gauge mount for 3rd Gen trucks
Kirwin
What are you guys who have a new truck seeing for RPM at 60 MPH? Is the engine noise significantly louder for the higher RPM you are seeing in the 4. 10? In my 12 valve this was the deciding factor for the 3. 55. Couldn't put up with the engine noise at 2500 RPM in 5th gear running empty. If someone would measure the diameter of your tire I can calculate the difference in engine RPM and figure it out myself. Thanks. Remember don't tell my wife, I am not allowed to have a new truck! Ken Irwin
Here is the 3. 73 numbers
Engine RPM v/s MPH with 3. 73 Diff. , 6 speed, tires 265/70/17
RPM 1st 2nd 3rd 4th 5th 6th Gear
500 2 4 6 9 13 17
600 3 4 7 11 15 21
700 3 5 9 13 18 24
800 4 6 10 15 20 28
900 4 7 11 16 23 31
1000 4 7 12 18 25 35
1100 5 8 14 20 28 38
1200 5 9 15 22 30 41
1300 6 10 16 24 33 45
1400 6 10 17 25 35 48
1500 7 11 19 27 38 52
1600 7 12 20 29 40 55
1700 8 13 21 31 43 59
1800 8 13 22 33 45 62
1900 9 14 23 34 48 66
2000 9 15 25 36 50 69
2100 9 16 26 38 53 73
2200 10 16 27 40 55 76
2300 10 17 28 42 58 79
2400 11 18 30 44 61 83
2500 11 19 31 45 63 86
2600 12 19 32 47 66 90
2700 12 20 33 49 68 93
2800 13 21 35 51 71 97
2900 13 22 36 53 73 100
3000 13 22 37 54 76 104
3100 14 23 38 56 78 107
3200 14 24 40 58 81 111
Excuse the formating but you get the idea.
Cheers Ken
Ken- these new trucks are quiet enough I don't think it matters anymore. I've driven 7 or 8 of them, both ratios, and most all are MUCH quieter at 60-70 MPH.
JH
I found another interesting little gem using Tim's calculator:
My 98 truck (and my 94) had 215/85R16 tires (30. 3897" dia. ), at 2000 rpm I was going 60 mph.
My 03 truck has 235/80R17 tires (31. 8031" dia. ), at 1900 rpms I am going 60 mph and at 2000, 63 mph. How 'bout that?
Dean
Don't know about your wife but I'm impressed. When I did the calculations and compared my 97 2500 with 4. 10 and the new 3500 with 4. 10 I am turning about 350 RPM slower now.
