Originally posted by Dean Upson
Parshal,
The operation of the oil pressure gauge is explained on page 8J - 32 of the 2003 Service Manual.
Under "OPERATION
ENGINE OIL PRESSURE MESSAGE - the instrument cluster circuitry restricts the oil pressure gauge needle operation in order to provide readings that are consistent with customer expectations. Each time the cluster receives a message from the PCM or ECM indicating the engine oil pressure is above about 41kPa (6 psi) the cluster holds the gauge needle at point near the middle increment within the normal range of the gauge scale. "
In other words a virtual gauge or glorified idiot light.
Dean
I'm reading this to mean that the gauge will consistently "point" the same spot on the gauge all the time. Mine does not do that at all. It points to the same spot when the engine is warm but consistently works it's way down to the spot in the picture (in my initial post) as the engine warms. I must have missed the previous discussion.
