I've found that there is a huge difference between pre and post-turbo temps at shutdown. I have an egt gauge hooked up to a pyro pre-turbo and added a pyro post-turbo that is hooked up to an ISSpro turbo-temp monitor. What it does is it monitors the pyro which is mounted post turbo and if it's above 300 degrees (this point is settable) it outputs 12v and backfeeds the ignition to keep the engine running even if the key is removed. So I can pull into the gas station (or whatever) and set the brake, put the truck in neutral, turn off the ignition, remove the key, lock the doors and walk away, the truck idles until it's below 300 degrees.
Now what shocked me was that when I first hooked it up I had my gauge attached to the post turbo pyro as well (to set the temp). I was amazed how often I was shutting my truck off WAY before the turbo was cooled off going by my pre-turbo gauge. I like having the gauge pre-turbo for performance reasons but for shutdown the post-turbo is a must, IMO. What I found is that some of the stuff people say to cool the turbo like decelerating in gear as long as possible (which I did), that look like they are cooling the turbo faster actually arent. There are many times that my pre-turbo egt gauge will read below 300 for 3-4 minutes before the engine shuts off (hence below 300 after turbo).
I think I have the best of both world's, pre-turbo pyro with a gauge to watch for high egt's in the best place, and a computer making sure my engine doesn't shut down until after turbo get's below 300 (I have an emergency kill switch right behind the ignition key too). See my post
https://www.turbodieselregister.com/ubb//Forum3/HTML/000507.html regarding the installation of the turbo temp monitor. Total cost for it was $180 and it's the most convenient thing I have on my truck.
-Steve St. Laurent - President of the
Great Lakes TDR, Chapter Forums Moderator
'98 Quad Cab Long Bed (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, Prime-loc remote fuel filter, boost & pyro gauges, TST Powermax, muffler eliminator, 5" chrome tip, BD Exhaust Brake, Isspro turbo temp monitor, Permatech spray in liner, Grizzly stainless nerf bars, Stull SS grill & bumper inserts, Front Draw-Tite receiver, BFG 285/75R16 AT KO's
[This message has been edited by Steve St. Laurent (edited 06-18-2000). ]
