Engine Shut-down For An Instant
ready to start bombing but have some ?'s
Check it out! Interesting Cummins 5.9L B Series applications
RMADSEN
MY '01 3500 SIX SPEED HAS SHUT-DOWN 5 TIMES FOR AN INSTANT IN TIME. BEFORE I CAN CHECK GAUGES ALL IS WELL.
THIS IS AN UP-DATE TO THIS PROBLEM. I TOOK THE TRUCK IN FOR THE CLOCK SPRING RECALL, (THE DEALER GAVE IT BACK TO ME WITH THE STEERING WHEEL 30 DEGREES OFF OF CENTER. ) AND THEY FOUND A CONTROLER "FLASH" THAT SHOULD FIX MY PROBLEM. THEY FLASHED THE CONTROLER WITH UPDATE. DM. ALSO, NO CODES WERE LOGGED WITH THIS PROBLEM. I HAVE NOT HAD A CHANCE TO DRIVE IT MUCH, I WILL UP-DATE IF THE PROBLEM COMES BACK.
HOPE THIS HELPS!
