Have a 1995 12v 4 x 4, 5 spd. Have replaced fuel shut down relays and solinoid. Adjusted solinoid to factory specs. Cleaned all terminals and dilectic grease. Replaced terminal ends on fusable links and starter solinoid contacts. Intermittently, while driving, engine shuts off. Originally would pop the hood, and pull the solinoid up into run position and everything would be fine until the next time. Have also found when truck dies can just push in the clutch, hit the key and it will re-start. Experiencing no loss of power or hard start. Primarily takes place while hitting bumps on the rough interstate. Does anyone have any suggestions on where to go from here? Thank you in advance.
