Other than the tach, what function does the engine speed sensor perform in a 5 speed truck? Today I talked to a guy at Cummins Rocky Mountain who thinks this is the culprit that's causing my performance problem. (see: "signs of pump failure" thread)
Wouldn't my tach not work if this sensor had failed? Does the engine speed sensor have anything to do with pump timing advance under acceleration or is it purely mechanical?
I'm beginning to think it might be the KSB solenoid that is to blame. Maybe its not closing and allowing the pump pressure to rise? What do you all think?
Please help! I need to exorcise these demons from my truck!
Rob
93 W250 LE, CC, 4x4, 5spd, 4. 10's, exhaust brake(tailgaters nightmare), turned up pump, boost/pyro guages, lund moon visor, weatherguard tool box.
Rob
